CV Connector Current Supply?
![Name: GDUFwWc.gif
Size: 26.3 KB](https://rennlist.com/forums/attachments/944-turbo-and-turbo-s-forum/1365443d1683266546-cv-connector-current-supply-gdufwwc.gif)
So it looks like a 10 gauge wire feeding the injectors and CV, breaking into 14 gauge to feed the CV and 18 gauge feeding the injectors. Each injector takes about 2.5Amps and two fire at once (stock 4.7ohm injectors), so 5Amps is going through at any given time. Ignoring component limits in the DME you should be good for 5-7.5Amps safely, possibly up to 10Amps but that may be pushing the old wiring.
Thanks Scott. Are you using the wire gauge as an indication of the supply current likely available? Probably a safe bet, though the factory was prone to over-kill at times. Wonder if there are any specs out there on the max draw of the cycling valve?
Thanks and agreed on the wires. Posts crossed -- was really focused on the circuit supplying the current rather than the wires, but agree the wires are probably a reasonable indicator of the current available. Fuse is a good call -- will look at that too...
Edit: The manual says the internal resistance of the CV is between 18-45 ohm, so that should be under 1Amp.
It's an electromagnet - so the coil will retain some heat as the current goes through.
More importantly to the OP, the cycling valve take an alternating current - so if you're just trying to wire it up to a 12 DC source, it's not going to function properly.
Professional Hoon
the 12v is consistant as that's where Rogue Tuning get their supply of 12V to the MAF
