MARYLAND, VA DESPERATE, need a 951 dme to get the car running
Old 03-30-2013, 10:47 PM
RevvAutoMD
RevvAutoMD's Avatar
nope confirmed it is just hopping sometimes on key turn but its dead there is no activity on the gauge, if one connector is bad and one good would it still show nothing? just curious
Old 03-30-2013, 10:55 PM
Rogue_Ant
Small Business Partner
Rogue_Ant's Avatar
Yeah - both reference sensors need to be working properly in order for the DME to try to fire the coil.
Old 03-30-2013, 10:59 PM
RevvAutoMD
RevvAutoMD's Avatar
harumph harumph harumph
Old 03-30-2013, 11:00 PM
RevvAutoMD
RevvAutoMD's Avatar
weeeeeelll looks like i get to fab up a link to the sensor cause the one is not gonna be repairable with what i have on hand
Old 03-30-2013, 11:02 PM
Rogue_Ant
Rogue_Ant's Avatar
If your reference sensor wiring is factory, then I highly recommend the replacement that Lindsey Racing sells:
http://www.lindseyracing.com/LR/Pors...4-HAR-REF.html
Old 04-01-2013, 12:59 AM
RevvAutoMD
RevvAutoMD's Avatar
ok made new harnesses and installed today
Old 04-01-2013, 01:01 AM
RevvAutoMD
RevvAutoMD's Avatar
ok checked your video on the previous page, extended cranking makes the air smell of fuel so im pretty sure fuel delivery isnt the problem, my tach now bounces matching your video. No spark still, what the heck could it be? I guess new dme is my last option?
RevvAutoMD
RevvAutoMD's Avatar
also i am jumpering it for any newcomers and i can hear the fuel pump going so fuel is good, new filters and some lines.
Old 04-01-2013, 01:12 AM
Rogue_Ant
Rogue_Ant's Avatar
Are you checking for spark at the coil, or at the plug? Check it at the coil to eliminate a possible cap&rotor issue.
Have you tried another DME chip? Perhaps the current one got fried.
After that, then I would try a different DME.
Old 04-01-2013, 01:51 AM
RevvAutoMD
RevvAutoMD's Avatar
will swap chips in the morning, then have to find a dme
Old 04-01-2013, 02:00 AM
RevvAutoMD
RevvAutoMD's Avatar
checked for spark at the coil and plug also tested for impulses at the coil.
Old 04-01-2013, 02:01 AM
RevvAutoMD
RevvAutoMD's Avatar
checked the fuel injectors before also, was getting some seemed to be pulsing them
Old 04-01-2013, 05:08 AM
MooreBoost
MooreBoost's Avatar
Grounds?
Old 04-01-2013, 08:22 AM
RevvAutoMD
RevvAutoMD's Avatar
Im assuming no one local has a spare dme?
Old 04-01-2013, 09:34 AM
Supachink
Supachink's Avatar
I've got a Spare DME and KLR, im down in Fairfax, by George Mason University. PM me if you are interested.
Greg
Quick Reply: MARYLAND, VA DESPERATE, need a 951 dme to get the car running
