oil pressure reading
i have a rebuilt engine and now it reads maybe 1bar at idle then shoots up to 4 or 5 as rpms increase. but at idle 1 or less. just seeing if this is normal. was gonna hook up an oil pressure gauge at sender tomorrow. im running 20/50 oil now. thanks
A healthy reading is 3 to 3.5 at idle when warm. I went through this and it was a faulty oil pump.
i just hooked up an oil pressure gauge at port. 90 lbs at cold and 25 lbs warm at idle. seems to jump to 70-80 when i bring it up to 3k rpms. im assuming crank bolt and oil pressure relief are correct. these items scared me so had a porsche mechanic assemble motor. though my exhaust fell off while driving and a couple boots blew off under boost. thanks for input. ive switched to lbs instead of bar becuase not really sure how it converts and my gauge reads lbs.
