what kind of turbo is this?
I found a relatively cheap turbo, but can't get too much info on it from the seller. They say its a t04 turbo,3 inch intake on cold side,0.60 a/r and #8 hot side that bolts on with some grinding of bolts. Any idea what turbo this is and what its is capable on a freshly rebuilt stock motor?
Its a turbo built by TEC (turbo engineering corp). Its apparently a t04e 50 trim with 0.60a/r and #8 hotside. So the question of the day is whats the turbo capable of on a fresh stock 2.5 motor?
Buy it, that is one of the best DDable setups you can run on a 2.5L. Should spool around 3200rpm and hold plenty of boost to redline. Depending on boost and fuel anywhere between 300 and 370rwhp.
