My GT30R Build
#31
Nicely detailed and informative thread, thanks for sharing. I wish the welds on mine were half as nice.
You may have been able to make the oil supply line to the turbo not much longer than the original one by using a much smaller oil filter and placing it under the intake manifold.
Thank you for sharing! I know how much time it takes to build and take pics at the same time. Then you gotta post up all the info. It can be fun though. I did the same, but I didn't use the Tial housing or turbo mount.
Excellent job. Only critique is that you put your O2 sensor in a rough spot. It works just as well 12" or more in the Down pipe and will live in a lot less harsh environment. Be prepared to change that out a bit more than regular. Also, avoid putting anything in the up pipe. It puts that sweet turbo at a higher risk of damage if any sensor or whatever is in there lets a small piece go into the turbines.
I can't wait to hear your post on how it performs / spools. Excellent turbo choice and a job well done.
It isn't clear yet because I haven't posted up the details of my exhaust, but that should come today. The O2 bung I was discussing was the stock one, which is still going to be used for the narrowband sensor. I have a separate bung in the test pipe for WBO2. I'm not sure if you thought I was going to be placing the wideband sensor in the crossover...?
In the past month or so I've been working through the break-in process for the rings / bearings / clutch. Already did the initial fire up and also the first drive. Need to change the oil again and put some real miles on once the weather clears up. While I tried not to get into boost it was almost unavoidable. This turbo spools so fast and lag is nonexistent as far as I can tell!
Most people post as they go however I felt this might be more exciting and coherent for people to have everything up front, so I waited until the project was complete. Overall it took me nearly 14 months to complete due to work / traveling / etc. It has been hard keeping quiet this long.
#32
Oh, so you've done all this and are driving the car now? So, feedback? Where are you seeing 1 bar?
#33
Professional Hoon
#34
Location: Bangkok, Thailand, Milpitas, CA & Weeki Wachee, FL
1 Post
[QUOTE=mclarenno9;10212376]
I had thought about it, but was worried it would turn yellow and start peeling at some point. I'd rather be able to spray some brake cleaner on a rag and wipe it down to clean it if (when) leaks develop, or if I change my oil filter
. Having said that, I did paint many brackets and heat shields however those pieces are small enough to throw in the bead blasting cabinet to redo quickly if needed.QUOTE]
Steve:
Too late now, but for the future, take a look at the POR-15 products from their website. I have had very good success with their coatings. However, don't use their reccomended method of application with a brush, using a spray gun produces a factory like finish. I am attaching a couple pictures of my control arms I did with a small gravity feed spray gun. This is a powder coat like ceramic coating that will not chip or peal and is brake cleaner proof as well!
Steve:
#35
1 Post
Unfortunately, I did not have this advice and painted my block per their reccomendation with a brush and it turned out OK, but not nearly as nice as the control arms. Here is the finished block:
#36
OH FANTASTIC. You are running it. I can see clearly that you know what the heck you are doing. Yeah, I thought that was where you were going to put the wideband. Thank you for clarifying. I still can't wait for you to see how damn fast that thing spools to 15psi. Should be right at 3K rpms.
I look forward to future videos!
#38
Also I love everything about this thread.
#39
Thanks for the kind comments guys. Hopefully it runs as good as it looks!
Eric, I'll have to give those coatings a try next time I have some parts off the car. Looks nice.![thumbup](https://rennlist.com/forums/graemlins/thumbup.gif)
Once I get a couple hundred miles on the bearings/rings I'll start cranking up the boost and I'll be sure to report back with logs/dyno/video/etc.![burnout](https://rennlist.com/forums/graemlins/burnout.gif)
For posterity's sake, here are a few closing shots:
#40
Rennlist Small
Business Sponsor
Rennlist Small
Business Sponsor
Hi Steve - Nice write up.
its too late for you project but there is a nicer solution for the AOS plumbing. The side output pipe from the AOS can (where you usually clamp a hose over it) will accept a NPT AN adapter fitting - it self taps in to the plastic very nicely. Then just add a 90 degree hose end. Looks great!
#42
In a word
WOW ....
That is some job .....
Great work, great write up, and now you can check into the insane asylum.![Wink](https://rennlist.com/forums/images/smilies/wink.gif)
Very impressed ...
Hi Five![thumbup](https://rennlist.com/forums/graemlins/thumbup.gif)
Regards
Ed
WOW ....
Very impressed ...
Hi Five
Regards
Ed
#43
Incredible work Steve! That engine bay is very impressive (especially knowing how quality it is in areas you cannot see). The thread has assisted me greatly with my build and I appreciate you taking the time to document it. Thank you. I am sure many others will find this thread extremely useful.
