Lobster bends
Professional Hoon
There is a popular trend going around with lobster bends and welds. basically where you get a straight pipe and cut it on an angle and turn it into a bend.
I had a go at doing this. My welds aren't the best but im still learning!
![](http://i107.photobucket.com/albums/m311/tha-wog-boii/file-43.jpg)
Usually people leave it like this but i thought i'd polish it to see how it looks.
![](http://i107.photobucket.com/albums/m311/tha-wog-boii/file-44.jpg)
What do you guys think?
I might use it for my intake
Very good !![thumbup](https://rennlist.com/forums/graemlins/thumbup.gif)
Man that seems like a lot of work ... (To make a bend)
Location: Bangkok, Thailand, Milpitas, CA & Weeki Wachee, FL
1 Post
Very good job Paul, especially for a beginner!
Have to chime in with Eddie though, just wanted to say you did it? 45 degree bends are readily available aren't they?
Professional Hoon
Thanks!
I had some free time so i thought i'd try it. It is a bit of work. I guess once you get the hang of it, it's easier.
Thanks mate, Yeah pretty much haha. Yep 45 degree bends are easy to get, cheap too. A lot cheaper then getting that made..
Pretty clean. All i need to fo is get a dremel and clean it up with a sanding wheel.
Lobster.. hmm. I like that term. I'm used to saying, "pie cut" I first saw it grow in popularity in Japan. I can't verify if that's the origin or not. Waaaaaaay too much work if you can use a mandrel bend. Very cool style though. Good work and Keep at it. You will get better very fast by making those kind of bends... there is a LOT of welding.
Professional Hoon
I agree, a lot of work! I can use a TIG but to get the very nice weld takes practice.
I'll try another one since i have more off cuts laying around. besides if it looks nice i'll use it for the air filter.
Nice first go!
This from the guy building my car. He's been at it for a bit longer than you though Paulyy.
Couple of his custom bikes.
Professional Hoon
I did use one that uses a whopping 60 amps of 3 phase power.
Realistically it's ~15 min per circle of weld. It look me longer because i had to figure out how to hold everything in place where a pro would have probably made up some sort of jig to hold it.
