Started winter suspension upgrade
#31
Not sure what I will do for the rear seat delete area yet, probably cover with light weight carpet.
Used the threaded boss in the hatch area to mount the canisters
Snap a rusty rear exhaust hanger bolt can't really complain that was the only broken bolt, called it a day I will drill that sucker out and bleed the brakes next weekend.
Then ready for corner balance and alignment, Racers Edge is 3 hours from me, I may make an appointment if they can do the job and me do the trip all in 1 day, we will see
#34
Tried the new suspension today at Barber Motorsports Park, after thunder, lightning and hail moved out of the area the am sessions were very wet, had a little scrape with the armco chasing a GTR... came in pulled the quarter panel back into usable shape, the afternoon sessions were dry, car handled great, hunted down the GTR and earned a point by well.... it is a DE after all. Once I sort thru video I should see that I improved my personal best time by a sizable margin.
#37
Damn, bad luck David. What tyres were you using? What next for the repair?
#39
Hankook V12 street tires, wide body has crossed my mind, or leave as is show a little "attitude" but will most likely just repair it back to stock.
Ran an autocross this morning, was within 2 seconds of FTD (a well set up S2000 on Hoosiers and driver only) me on street tires and a passenger. I am pleased with the suspension.
1/2 tank of e85 and my 160 lbs
