RogueTuning logger up and running
Finished wiring in the M-Tune and DME logger this weekend, am pretty stoked with the end result out of the box, so congrats to Josh on a great product.![Cheers](https://rennlist.com/forums/images/smilies/beerchug.gif)
On road pressure testing found a bov hose that I'd forgot to tighten
, straight after that I blew off the intercooler pipe, so yeah i've had an enjoyable day doing some logging runs.
I'm running a tech edge 2b0 and ended up modify the config on that to adjust the linear output voltage, the dme logger was showing about 0.3 leaner than actual at idle, I should do a dyno run I guess to cross check my readings across the range.
Seeing the AFR lock in steady at 11.5 from 10psi upwards, very happy with that!
![Embarrassment](https://rennlist.com/forums/images/smilies/redface.gif)
SID, I've fixed that! refresh your browser for the northern hemisphere pic lol
cheers Refresh, the logging is already paying dividends, Joshua pointed out that my coolant temp is a bit on the high side so am going to look into that.
Small Business Partner
That is something I've have planned to add to the logger... Let me do some proofing first, and when I'm happy I will update the logger software so it will read out 'calculated hp&tq'.
