HELP: Axle hitting hub
Just got my car back together and whenever I hit the accelerator I get a loud clunk from the rear end. I went through everything and have determined it is the right side axle hitting the hub. I am able to replicate the sound easily and there is literally no room between the axle and the hub when it is in a resting position. I have the Lindsey motorsport axles and CV's. Any ideas on how to get this to shift back to normal as I never had the issue before. I have a solid trans mount & Lindsey Ultra engine mounts that are all working properly. I cant get the trans to move to the left side any further to try and pull the axle away from the right hub. Need to fix it tonight/tomorrow cause wont have any time between then and Sebring club race to get under the car.
Brian
Brian
Well took the axle out and found one of the CV's was bad. Kind of surprised given that these axles and CV's were supposed to be the best you could get. Found the inner race had some fairly good sized pits in it and it has been binding I guess. Bad part is these were brand new and I have maybe 25 hours on them with a stock motor so no crazy HP being pushed. Now to call Lindsey on Monday and see what we can do. Hopefully I dont have to shell out another $600 for a new axle cause that would suck.
That's a bit of a concern. Do you have tired engine or trans mounts that could cause excessive lateral movement and put strain on the axles/CV's? Assume the axle is fine but the CV needs rebuilding?
Can I ask....How do you know the axles are hitting the hub?
I just replaced one of my axles. The old one was clicking really loud (louder than I have ever heard a CV click). I remember Sid talking about having this problem, so I went under my car and tried to move the axle with my hand. It was loose, and I could move it maybe an 2in total (1" each direction from center), but I couldn't get it to hit either the hub or the transmission. I know I can't put the same pressure on it as the engine, even though I'm pretty tough
.... but I couldn't see it happening at all. Then I tested the new axle packed with fresh grease, and though it didn't move as much, it still moves a bit...
How do you guys know the axle is hitting the hub? (I'm not doubting. just curious)
You can take ahold of the cv shaft and mov it toward the hub and make the same noise.
Pat, it was nothing to do with trans movement. The wear allows lateral movement. I've had this discussion before.
No the engine and trans mounts are in good shape. I have a solid trans mount and a new set of Lindsey ultra mounts. Still dont understand how this happened but it is what it is. Doubting there will be any warranty since I bought them 18mths ago but only have maybe 25 hrs on them Bummer.
I don't think I've ever heard of the axle itself going bad (barring accidents) -- it's essentially always the CV itself.
Hate to say it, but doesn't surprise me that the LR axles didn't last you long...they haven't had a good track record over the past couple years.
Hate to say it, but doesn't surprise me that the LR axles didn't last you long...they haven't had a good track record over the past couple years.![Frown](https://rennlist.com/forums/images/smilies/frown.gif)
Do you have the part # and/or your source for the vanagon joints? I have some newly acquired porsche axle shafts (my old ones) that I would like to put some new vanagon joints on.
Which wear are you referring to Sid?
As Brian has mentioned though, the mounts are all good. Be very interested to hear what they come up with?? Is it possible that some crap got in there and created the premature wear on the Bearings?
I have some of these (968 version) on my car plus aftermarket engine/trans mounts. Was almost going to buy some more as a backup spare just in case. Perhaps I should just go the way Sid has but buy a 6 pack of them!!
