Smog test ahead: Will high octane gas alter smog test results?
Yeah, it's been near freezing! brrrrr
When I use a little E85 (actually, denatured alcohol) for smog tests, it lowers CO and HC while raising NO.
Maybe it's a little lean. Can you try tuning it to be richer?
i.e. instead of leaving it at 14.7 and 14.5 we changed it to 14.7 to 15... ish
And I failed with hight NO numbers
So now we went back to 14.7 - 14.5 ish thinking it was too lean hence causing the high NO #'s
On the e85, Oh crap ... I thought it would do the inverse ( by cooling the exhaust )
I didn't put it in yet ....
Right now I am now changing the plugs ( they don't have a 1000 miles on them )
I am trying to do whatever I can to eek out a pass...
Also I am changing the oil ( same mileage as above )
Below is the latest smog test ( which I failed ) and the one from a little over a year ago ( which I just passed notice the HC was pass by one !) That was with a different cat ( orig stock ) vs the new one I am using
None of this **** makes sense ....
Its a new maybe a year old (used for smogging only) after market cat that is CA CARB approved ...
I was thinking I heated up the cat enough, but some others say, maybe not ... As ya know its been pretty cold here the last few weeks so I don't know if the car is heating up the same....
I think that some e85 should help bring down the temps ,,, no?
regards
Ed
regards
Ed
I would suggest installing a WBO2 system and put a switch on the narrowband O2 sensor blocking the signal to the DME on demand.
With the wideband you can get a good estimate of the probability of passing the smog test (good if it is near stoichiometric) and the switch can be used to see how close the base map is to stoichiometric. If the base map is too far away, the closed loop configuration (NB connected) will not be able compensate.
When the NB sensor is disconnected the DME internally creates a 0.5V signal, so it does not do any compensation.
I can also recommend training your nose to detect a well-functioning cat … seriously. It has saved me a couple of times by smelling the need to go for a brisk ride before the actual test.
Laust
I'm no expert but I think if you go back to the richer setting (which resulted in 0% O2 on your previous test) you will pass with your newer cat. Get a pretest!
And good luck with this retarded California smog rubbish.
regards
Ed
regards
Ed
See if the NOx comes down with AC on (so all the radiator fans are running) and the hood down to channel the air through the engine compartment. Or go see Jeff.
I checked my records, and after 18 months my DEC cat was at 795 ppm NOx at the low speed test (but plenty of room at the high speed), so maybe they just don't last very long.
Pete, did you use your cat just for smog test only, or do you run it all the time .. Reason I ask is that this CAT was only used for one test, so I was expecting no issue ...
I was obviously wrong
![Roll Eyes (Sarcastic)](https://rennlist.com/forums/images/smilies/rolleyes.gif)
Yea sadly the idiots are running the show here ...
A well-functioning cat likes to have a little HC (stoichiometric or a little richer) to work with in order to heat up.
Laust
Laust
Sorry I missed this post
Hope all is well
Actually I have the ZT2 wideband and have it tuned to 14.7 bouncing to and fro to 14.5 now .. The failed test it was a little on the leaner side so I am hoping with the new plugs, richer mixture an oil change, and a litte E85 I may squeak by
![bowdown](https://rennlist.com/forums/graemlins/bowdown.gif)
Regards
Ed
Eddie, I'm trying to get my car through CA smog too and I've got a lot of the same stuff as you(I'm the guy with the Baltic Blue car that was FS at Parts Heaven this summer). How did you get through visual? It looks like the VR MAF doesn't have a CARB cert on it.
![ducking](https://rennlist.com/forums/graemlins/icon107.gif)
How are ya ....? I guess you didn't sell your car ...
I am adding to my list of changes ... now I am going to change the O2 sensor as well
So I did
Plugs
Oil and filter
O2 sensor
going to heat the cat up more
and maybe e85 ...
As already stated earlier in this thread, e85 will raise NO, seems counterproductive to what you are trying to do. Have you checked for any small exhaust leaks, such as by the waste gate and where the collector meets the crossover?
To pass in Georgia w Vitesse Stg.ll, Have done a couple things over time; goal to reduce combustion temps producing crazy high NOX. Lowered the fuel pressure w/ the AFPR and passed for many years. But in 2012 for some reason, that wasn't working even w/ a new CAT, so the guy running the machine ran the test in a higher gear/lower RPM to reduce combustion temps & it passed.
