Broken Block
Old 01-04-2013, 02:46 AM
TonyG
Rennlist Junkie Forever
TonyG's Avatar
I've seen it. Get a aluminum deck plate, made out of an an aluminum with similar expansion rates to the factory block, machined into the new block and you won't have that problem.
Sleeves are strong, but they have their own issues.
Sucks... BTW, I've been spending a lot of time in Prescott. How far are you from Prescott?
TonyG
Old 01-04-2013, 01:16 PM
Thom
Thom's Avatar
Originally Posted by refresh951
Any signs of detonation?
Not on the piston top, according to the pictures.
George, can you post a pic of the head?
Old 01-04-2013, 03:04 PM
944hal
944hal's Avatar
Had something similar happen to a friend. What we thought was a blown head gasket was, when we pulled the head, #4 cylinder wall cracked from the top to about the lowest point in the piston travel. Stock engine in a PCA E class race car.
Old 01-04-2013, 03:38 PM
odurandina
Team Owner
odurandina's Avatar
Location: one thousand, five hundred miles north of Ft. Lauderdale for the summer.
Originally Posted by Rogue_Ant
odurandina - has something changed? I do still want the engine.
Give me a call, I don't have your number...
thanks, Josh.
good to see she'll be in capable hands.
Old 01-04-2013, 07:26 PM
refresh951
refresh951's Avatar
Those pistons are from MM951 not George
Old 01-04-2013, 07:30 PM
George D
George D's Avatar
TonyG
Tony, Tucson and Greer are both about 2.5 hours away driving.
Old 01-04-2013, 07:45 PM
George D
George D's Avatar
Sorry to hear about this George. Glad to hear you are back up and running. What CR was that build? Any signs of detonation?
8.5 CR. Same as the new motor.
Old 01-04-2013, 07:47 PM
Thom
Thom's Avatar
Sorry I read too quiclky!
MM951, can you post some pics of the head used with these pistons?
Old 01-04-2013, 08:34 PM
George D
George D's Avatar
Originally Posted by rlm328
Looks like a candidate for a Darton MID sleeve.
I'd love to hear anyone using the MID sleeves to share their experience with their motors with at least 10K on them.
Old 01-04-2013, 08:36 PM
George D
George D's Avatar
Originally Posted by blown 944
George, I may be interested in that block if you are gonna get rid of it. I'm going to do a different type of sleeve for my big engine, and this would work for it.
Sent you a PM.
Old 01-04-2013, 09:37 PM
George D
George D's Avatar
No detonation visible once the head was off. No detonation was recorded from the knock sensor, nor human ear. Not one knock recorded during the tuning runs. This motor was showing great promise till the "poof" of black smoke from the tail. Glad the tuning was done on the dyno. Immediate shutdown then teardown to find the culprit as posted in color.
Old 01-04-2013, 09:55 PM
Rogue_Ant
Small Business Partner
Rogue_Ant's Avatar
George - what fuel? And what was your timing advance (if you don't mind)?
Old 01-04-2013, 09:57 PM
refresh951
refresh951's Avatar
I figured you were doing the knock monitoring. I appreciate all the pioneering work you have done with your car.
My next thought would be a fatigue fracture. Impurity inclusions in the aluminum can lead to fatigue initiation sites which result in high stress concentrations. A crack is formed and then propagates. With the power you are running, hidden weaknesses would be exposed. Be interesting to have a Metallurgist look at the fracture surface.
Old 01-04-2013, 10:26 PM
George D
George D's Avatar
Did have it checked. Looks like the OE casting was the issue. We all mess up. Could have been a late day when the quality control folks were , "almost off the clock".
It did some time with a NA 968 for many miles. When we stress the bores, you find lackluster supervision towards quality control.
The builder is making this right. I'm thankful this happened during the builders tuning, and not my time in the car. We both loose, but I'm not shipping the car back to him. Happened in his shop.
Old 01-05-2013, 03:00 AM
azbanks
Freedom Enthusiast
azbanks's Avatar
Prescott to Greer in 2.5 hours???? D@mn, your car IS fast.
Payson to Greer in 2.5 hours I would agree with.
Tony, if you have room to bring my part to Prescott, I'll come pick it up from you there.
Quick Reply: Broken Block
