short shifters breaking
I ran a short shifter on a 5 speed some years ago. When it worked it was nice, but if you slightly missed the shift it would 'graunch' the gears, particularly when the car was cold. Anyone else find this?
I bought my short shift linkage from Paragon Products years ago and it's been working fine and shifting pleasantly ever since I have had it. I ignore who actually makes it but it looks 99% identical to that Schnell unit... Will be checking it up close for wear over the weekend.
I had a schnell unit in my 1987 924S that I tracked for 2 years and was also my DD, Never had a problem, But As noted I did notice when cold it would have a tendence to grind, But once it warmed up, all was good
Rennlist Small
Business Sponsor
Rennlist Small
Business Sponsor
Can I ask a 'dumb' question?
Why do you guys want a short shift set up? if your bushings and shift lever are in 'like new' condition the stock shifter is really nice. Fixing a sloppy shifting lever/rod/linkage by adding a short shift kit is not the best solution!
Me personally, I think the stock throw is to long, Yes its a nice steup but I feel it needs a little more, I like the shorter throw and the ferm mechanical feel, Feels better when driving.
Rennlist Small
Business Sponsor
Rennlist Small
Business Sponsor
I also prefer the feed back you get with the regular throw, all the short shift kits I have used have no real feedback from the trans and you just feel like you are 'man-handling' the transaxle in to gear.
Anyway - my main point is that the short shift kit is not a good way to fix a sloppy shifter, replace the shift lever, the white bushing and if needed the long shift rod first.
Have you driven a stock system that has been recently rebuilt? New shift lever, shift rod and bushings will make a huge difference.
I too think the stock shift linkage has a bit too much throw. My S2 had a nice tight stock linkage. So I know what it feels like. I love the feel and throw of a short shifter linkage. Mind you I hate those 'short' shifters in the cab that replaces the shift handle, and is literally just shorter. Those are retarded IMO. But it's all personal preference, and I don't blame anyone who likes them.
I lost my stock unit during my build....I think it fell into the recycle bin in the garage otherwise I would have left it alone.
Did not know it was missing until I went to put in on. Doh!!!!!
Lol!
