Side exit exhaust?
#48
Professional Hoon
If you want a wastegate dump. Point it to the floor and out to the side.
Or after the front wheel. But no point because the pipe will be lower than usual.
#50
Professional Hoon
It's not, I've seen under my car enough times to know!! lol!
To the side before the rear wheel is doable, there's room. Unless you make a tunnel around into the chassis.
#51
Side exhaust
Guys,
This is my Wide Body V8 Street 944, I will have 3.5" SS oval pipes come through these opening with a Carbon Fiber bezel when finished.
Max
Max
#53
A pic (or three) showing the underside of the area where the exhaust will penetrate the body flare/wheel well would be greatly appreciated - Thanks!
#54
Jay,
I will take some pictures of the SS oval merge pipes that I fabricated this week for you.
We did not modify the floor pans, but we did modify the rocker panel to accept the oval tubing that we welded in.
Max
Max
Dakota Pope (07-31-2019)
#59
I added another pipe.
3" off the turbo into a splitter, then 2x 2 1/2" pipe flattened down to 2"
then a 2 1/2" pipe for the wategate
The first pipe is the wastegate dump
