Winter project - oil pan gasket (and while I am in there...)
Odd Posts
I will be having the oil pan gasket replaced this winter. I am thinking while in there I will do the new bearings fitted and maybe a two piece crossover.
Looking to do this PITA project only once, so while we are in there what would you suggest be done from a maintenance/upgrade perspective?
Fergus whasup...The bearings might be a good idea, maybe I've been lucky but I usually just check the #2 rod and decide from there. With out some work to the crank, a bearing swap would seem like small gain for cost of bearings. Some other trivia...I'd sure want to get a good look at those AOS seals. But that means a turbo pull. And, it would be good to know the motor mounts are ok. Maybe before you start, pressurize the coolant to know there are not leaks. Get on line with McMaster and order up series of m6 and m8 bolts they have pretty gold, grade 10 ones for cheap.
Bruce
PS...what recipe are you using to seal the gasket - everybody seems to have a different preference?
Bruce
And, I will definitely agree that pulling the engine is the way to go... I've done it both ways now, and it's immeasurably easier with the engine out. Plus, that'll give you the chance to get to things like AOS o-rings, balance shaft housings, RMS, oil cooler housing... everything much much much easier. And, as an added bonus, it gives you the opportunity to CLEAN everything thoroughly. Having everything clean and leak-free will make anything and everything you do in the future suck way less.
Anyone have specs for the skirt around the pickup tube?
from the top of the bowl if you will -- how wide is the skirt.
Want to add one to mine. Is the pickup aluminum or steel (for welding purposes)?
mike
mike
