max bore/stroke possible for different 924/944/968 engines?
I was wondering what the biggest you can bore/stroke a 2.5L 944 engine? Also 944 2.7L, 944 S2, and 968 use the same block*, how big can you bore and stroke this block?
* http://www.porsche968uk.co.uk/porsch...evelopment.htm
Professional Hoon
you don't want to bore out the standard block, the sleeves will be to thin..
unless you use DArton MID wet sleeves and you can go 3.2 with the S2 engine.
IICR there's a thread with a 3.4L build. not sure where it is though. in rennlist obviously. i did a quick search and no luck.
Better options for us now
