valve springs and shims... Why does valve spring height matter?
Professional Hoon
This got covered so new question
Why does the valve springs need to be 41 +.5mm?
When i took the valve spring shims out, they're where all over the place, 3 in 1, 1 here or there and 2 everywhere else. (doesn't make sense to me)
I just did this for the intake valves for the time being.. I put the intake valve back in and put the top retainer in with the clips, I worked out the distance from the bottom of the retainer to the surface the cam tower sits on.. (lets call the distance a). Then i got a depth gauge and measured from the surface where the cam tower sits on to the surface where the shim sits on and got the distance b
Lets add the thickness of the retainer: c
Now when i did the math (pretty simple)
a+b+c = spring height (x) am i right?
or am i suppose to subtract the retainers (c) and we'll call the bottom one d?
Because when i did this for all 4 intake valves, they all added up the same heights. IICR they where all 45mm from the tip of the spring retainers to the bottom of the spring retainers.
Thus needing 4mm shims which doesn't seem right.
Anyone have a picture or can describe what the valve shims look like? and the location of these?
It doesn't seem like i've got shims on the intake valves. we'll im not to sure.
Thanks.
Thanks.
when you pull the valve spring retainers and pull the springs out, there are seats under the springs- under the seats are shims. There is a standard height for the spring assy and the shims make them all the same, so some have shims and some do not....some have two.
Adjusting valve springs as described in the FSM assumes that all springs have the same stiffness, which can be incorrect.
A better method is to figure out the developed stiffness of one spring as installed with the required height then adjust the heights for all other valve springs so that they return the same developed stiffness as the first spring. By doing so you balance out the effort required to open all valves.
Professional Hoon
So i should get the stiffness of all the springs and set the height to make the stiffness all equal? and not worry about the springs all being 41mm high?
Yes, but make sure you don't end up with installed heights that are "too" remote from the two values mentioned in the FSM. You have to decide after measuring each spring which one is going to be your "average", or "benchmark".
Like Thom said. A shop can check the pressure at installed height for cheap. Then you can "adjust" the installed height to match the pressures, but any spring that is too far out of bounds should just be replaced. Too much adjustment will lead to other problems.
In other words, the springs should be real close in pressure, anyway. I'd stick to using the shims for installed height.
Professional Hoon
by the looks of things, every intake spring will have the same shim and so will the exhaust valves.
Your machine shop guy should have a pressure gauge that compresses the spring to check the spring pressure. They should all be pretty consistant across the board. He can also help you sort the shims out also, but he'll have to have the head so he can measure the heights...jus sayin...
