Boost control?
Boost control?
What is everyone using for boost control now? Hoping to wrap up my go fast setup soon but I don't have anything for controlling boost.
I am using a Tial Wg btw.
I have an Apexi AVC-R. Too many features for what I need but I have it set for 14psi and 17psi map settings. My biggest complaint is it only reads in BAR, not PSI, but that point is moot since I have my Zeitronix A/F gauge with boost read out below my radio so I moved my EBC to the glove box.
Had Greddy EBC but went back to the "****" and had it fabricated to replace the cigarette lighter for OEM look while having it right there if I ever need it.
Very happy with EBoost street. Has 2 settings/boost groups. Large LED readout shows boost in psi or Bar - also records peak boost. Lots of features but works simply. Now that I understand it I could walk someone through setup though admittedly I had mine professionally installed. It has over boost protection as well and will lower boost if the threshold is exceeded. You push a button to switch between 2 settings or you can turn it off to run spring pressure. Worked great at the track with very stable boost levels at WOT.
Professional Hoon
