WHP Guestimate?
1 Post
WHP Guestimate?
Hey fellas, probably a dumb request however I would like to get an idea of what I should be putting down. I have an 86' turbo with a chris white cylinder head, upgraded camshaft, piston and rods. Fabspeed 3" exhaust, 46?mm wg from Tial, a K27/8 turbo ,MAF sensor (brand unknown) I want to say it is a 2.8l but I'm not 100% sure of that. My AFM is in a happy zone mostly 14 to 16 and I run 12psi most of the time, with a mbc and race gas switchable tune. As for supporting goodies, it has a stock gearbox, with a lightweight flywheel and 930 clutch. The PO had Rouge do the tunning. Thanks in advance anyone, also any help/ideas about my car would be great.
A lot depends on the displacement but I'd say 300-330 rwhp, but again tough to nail down unless you know the exact build. A 2.8 is a stock 2.5 piston and rod with a 3 liter crank, I believe. Someone with more knowledge will chime in I'm sure.
Take it to a dynojet dyno to find out.
Or go do a 1/4 mile.
I have the same turbo. I have M-tune and a Lindsey head. I have a stock cam. My car is a 2.5L
Dynoed at 266whp at 11.9psi, estimate 266 x 2.8 / 2.5 = 298 whp at ~12 psi.
Dynoed at 328whp at 14.5psi, estimate 328 x 2.8 / 2.5 = 367 whp at 14.5 psi.
Not sure if this is accurate, might not be right to multiply my numbers by 1.12 for displacement but it gives an idea.
1 Post
No I'm pretty sure it is 2.8 l block with a 3.0 crank. Looking back I don't think I included that in the initial post. I really need to get the documents from the mechanic who built it, Steve Kramer in Michigan if anyone knows him. I spoke to him a few times on the phone just haven't gone to the shop.
These motors came from Porsche with one of two different bore sizes --100mm or 104mm. The 100mm blocks are the 2.5 liter blocks, and the 104mm blocks are generally known as 3 liter blocks. Check the water passage at the front of the head and see if it is bolted to the block with one or two Allen head bolts--or get the block number and post it up. Separately, Porsche made two basic crank sizes--78.9mm and 88mm. The 78.9mm crank with a 100mm bore makes a 2.5 liter motor. The 78.9mm crank with 104mm bores makes a 2.7 liter motor (which Porsche made only as an n/a and only in 1989. An 88mm crank with 100mm bores makes a 2.8 'stroker' motor, which Porsche never made but was a fairly popular modification back when Andial was selling the parts. An 88mm crank with 104mm bores is a 3 liter, which is currently popular. Beyond that, anything is possible with sleeved cylinders in non-stock sizes (common) and custom cranks (not as common).
