VNT,,, Oh yeah I said it
#31
Small Business Partner
That is a good question, and funny enough is an advantage of having the turbo mounted on the 'wrong side' - it gives a little bit of time to cool the exhaust before hitting the turbo.
Regardless, we will be testing this combo for daily-driving, and on the track (road & drag).
#32
Location: Bangkok, Thailand, Milpitas, CA & Weeki Wachee, FL
1 Post
Josh, in your required items list, I saw no mention of a turbo mount. I can't imagine this turbo even remotely mounts up to the stock mount. Is it just suspended from the up/down pipe, or did you guys fabricate a new mount? What size is the compressor inlet, 4"?
#33
Josh and I are working on some other ideas with this turbo
Water cooling and oil lubricated
Best of both worlds!
#35
Clarification - this setup uses the factory engine/turbo mount - but has an "in-between" piece that mates the turbo center-section to the factory mount.
#36
1 Post
Sounds good can't wait to see how this project evolves over the next few months. Since thinking these turbos would never be adaptable to our cars, I have never priced one. What kind of ball park price for just a turbo? Figured you could save me the time of a search.
#37
1 Post
Even with this piece, the center section must be welded? I have spoke with Garrett engineers about this and was told it is a big No No.
#39
There isn't any welding on the center section. Dave has a pedestal between the mount and the turbo. It bolts to each one individually.
#41
1 Post
Just performed the search and these turbo's are very reasonable, especially if you roll the dice on a used one. Even the polished powermax brand new ones are not that bad at $1,300.00.
http://www.ebay.com/itm/GENUINE-GARR...ebf2a6&vxp=mtr
