Rennbay Lines with Lindsey Rail
I recently got a used lindsey rail and adjustable fpr. I have the two lines that go to the FPR with AN -6AN fittings, but not the line that connects to the front end of the rail. I believe that the size of the fitting on the end is a -6AN (dont know how to measure but its the same size as the fitting before the marren damper on the rear).
-Is it possible to convert the rennbay lines that I have to work with the lindesey rail?
Would i use something like this?
http://www.summitracing.com/search/D...?Ns=Rank%7cAsc
Can i just cut the aeroquip line and attach one of these -6AN swivel 180 ends and be good to go? Worst case sceario order the Lindsey Lines I guess?
Thanks,
Greg
Thanks,
Greg
Double check whats on the front of the LR rail, but if its a -6an just order a 180 degree -6an push-lock hose end.
http://www.jegs.com/p/JEGS-Performan...62951/10002/-1
BTW, and yes just cut the old fitting off and replace with the new one.
Thanks Techno, that looks like the correct solution for the aeroquip lines that i got from rennbay. Ive tied to find out how one would measure an AN fitting, but im still unsure as nothing is matching up right, its about 14mm diameter when i measure it with my calipers.
I think the hose for the fuel feed is 3/8ths if i remember right, if your using Aeroquip it should be printed on it. But the equivalent size for 3/8ths is always -6an.
I had a LR rail and it was defintley a -6an feed, i remember because i previously had a CEP rail which had a -8an feed so i had to get a reducer.
Yeah it should be a -6 AN feed. I also bought a used LR fuel rail. If you give a LR a call they will work with you and you can just buy the parts that you need. Traci walked through what came in the kit normally and we checked off what I needed and was able to just buy those parts.
Thanks Sparky, but I already have the aeroquip lines I did last year from rennbay, so I was just trying to see if I could modify those to work or if I needed to get the one line from lindsey. It seems that with the push lock connector that techno linked will work perfectly (good thing i left some extra slack in that fuel line )
