No Boost Pressure
#61
Professional Hoon
Either i've missed something.
Or there's a mouse with fire proof skin holding the turbo back..
I'm not sure if the AFM should flutter (Josh? is this suppose to happen?) I don't think so, because i recall my AFM being not firm but firm enough for the boost to pull it open and it to be slightly open on idle.
Is your car put back together?
Your by pass valve shouldn't open at all, only on vacuum.
#64
Car is still apart, I think I'll leave it that way until I can definitively find why this is happening.
When I pressurize the system from the intercooler inlet with the AFM off, I can hear the bypass valve dump boost at around .5 bar.
#66
I did the pressure test from inside the J-boot this time. In my curiosity, I pulled the ICV hoses from both the IM and the IC pipe. I blew into the IC side while plugging the other. I hear air escaping from under neath the IM, which probably means the valve itself must be shot.
#71
Essentially, all the air leaks out of it when you plug the outgoing hose. I would call that a major leak.
#74
Professional Hoon
I'm slightly confused. Does the valve leak (back into the intake) or the whole unit leak to atmosphere? If it leaks to atmosphere it'll make some sense to no boost.
#75
The valve leaks to atmosphere. I plug one end, and blow into the other, the air escapes to atmosphere. That is a whopper of a hose too, which is way I'm thinking along these lines.
