Help me Please
+1 .... and they can probably even come to you. Might be cheaper yet.
If all else fails you can get a circular diamond saw bit that fits around the bolt. Then you drill out the aluminium around the bolt and pull it. You will need to timecert the hole afterwards, and may also have to go up one dimension on the bolt. Only do this if there is enough material around the bolt to be safe. This is a last ditch solution. Try everything else first
TIP: This works to drill out bolts around broken extractors.
I use a set like these. The diamonds will wear off with use.
Wow, those things are awesome
So an update for you!
Mix, 3 nuts 1 $109 harbor freight flux wire welder (actually works a lot better than you would think and runs on 120v) some release agent some burnt cardboard 'shields' an on fire cloth 'shield' and this is what you get
As you can see the problem is solved and I'm super happy so thank you all for you help and suggestions, just waiting for Lindsey to finish my head no then time for some fun, hopefully
Nice work, there is always something extremely satisfying about getting out a broken fastener. Same bolt on my car broke with barely any torque at all, heat and vice grips worked for me.
