TonyG > New Race Car Build Thread
#1321
These kind of mods are pretty much out of most people's league but it's interesting to see fully developed cars like the latest contributors on this last page of the thread.
We race PCA, so unless you are building up an all out GT car, class rules would not allow aftermarket transmissions, and while I really have no reason to investigate this avenue for SP2 and SP3 cars that we race, it made me wonder,
1) In a PCA GT car, you could probably get away with a PDK transmission as it would be "factory Porsche gearbox".
2) Following Tony's links to the pneumatic shifter setup and the transmission itself, by the time you start adding up all the necessary hardware, sorting out the software (as Duke stated)....would it not be possible (and way less expensive) to just find donor parts from salvaged Caymans and just adapt this transmission...?
I was in the transmission business for 25 years, so naturally, when the PDK arrived on the scene, I was curious enough to read as much as I could, although at the time, not much information about internals was out there (probably due to proprietary reasons) and the factory was the only way to get a unit either repaired or refreshed was through a factory exchange program.
When you hear the PCA class Caymans with PDK pass by on track, the gear change speed is unbelievable and it, by design, should be even faster than any pneumatically shifted conventional gearbox, since by design, if I understand correctly by the limited information available at the time, the next gear is already engaged before it's actually selected by the use of twin input shafts (PDK = Porsche double coupling).
T. Simon
T. Simon
#1322
Rennlist Junkie Forever
The GM ECM has a IAT ignition table used for when the IAT fails. Chopping the IAC signal will make the ECM use that ignition table (instead of the normal ignition table) which can then be mapped as necessary to get the engine to unload.
TonyG
#1323
Here's the update....
Albins trans on the way. Be here before the next race. But unfortunately, I'll have to do the next event (California Festival of Speed in Fontana) with the 5 speed.
Anyway, broke the clutch and bell housing in the last race.
Needed to go to a super light clutch assembly for the sequential, so it is what it is...
BTW, I have a nice Spec aluminum flywheel and disk in good shape for sale if anybody needs one >>> IT's for a LSx engine in a 944/968 BTW.
TonyG
TonyG
#1329
Our plan is to interupt the IAC signal, via relay, when the GCU sends the signal.
TonyG
TonyG
T
#1331
I realize that. I didn't know if you were referring to the previous or the new disk setup. But in both cases, I don't know that they are made out of.
The previous disk is a Spec Stage 2+. Very nice engagement and could easily be used for daily driving. No slippage with over 500RWTQ and over 600RWHP.
The new disk is the Spec Mini Twin. Rated for even more power. Definitely not a clutch for daily driving. But with the new sequential, the clutch won't be used except for moving around the pit area so it is not an issue.
TonyG
TonyG
#1332
Awesome build, and great vid clip. Just out of curiosity... Do they even allow wet-sumps on that track? :P
That is some serious sustained Gs on the big bend.
#1333
TonyG
#1334
It's been a while since I've posted any updates. So here goes...
Been dealing with weak CV joints and stock 944 transmissions, which have proven to be weak, and geared incorrectly respectively.
That said, I ordered an Albins sequential pneumatic paddle shift transmission with all the goodies. Waiting on parts still.
In the mean time, the car has been running good. And have been racing it a lot.
Last weekend at WSIR, did an official 1:21.3 on used tires. Won pole, and the the first race. Took a 2nd in the second race (see video below). Broke the clutch bell housing in 2 pieces in the 3rd race... which is probably why the car shifted poorly in the 2nd race... which you can see at the start where I got the jump, but the car wouldn't go into 4th gear.... nice. I couldn't shift it fast the entire race.
What I can say... is that once the sequential trans is in... the reliability goes up exponentially, and the car will probably drop close to 2 seconds per lap due to the no-lift shift, the automatic rpm matched down shifting, and having gearing that takes advantage of the engines optimal power band. (sucks coming out of corners at 4000rpms... or less depending on the track).
What else... took out the Cool Suit system and purchased a KoolBox IV a/c electric a/c system, the dry sump works perfectly, went to 997 RSR rear suspension uprights, and a few more other small things.
Here's a video of last weekend. 35 cars in the field, 7 in GT1 (my class). I took 2nd in this race (won the first race).
TonyG
Tony Garcia - POC RedRace #2 Feb5, 2016 WSIR - YouTube
https://www.youtube.com/watch?v=lijWSThbmaQ"]Tony Garcia - POC RedRace #2 Feb5, 2016 WSIR - YouTube
TonyG
Love this!!!!
You kicked *** buddy
#1335
Well.... Here it is! Woo F'N Hoo....
Albins ST6-M
Ramp Style LSD, 996TT output drive hubs, multiple drop gears, pneumatic paddle shifting
TonyG
Albins ST6-M
TonyG
