TonyG > New Race Car Build Thread
#214
Cup Springs.
#216
Rennlist Junkie Forever
Who setup/valved your shocks?
It's my understanding that the Ohlins are very generic in their "as delivered" state with the resolution of the adjustments being very fine. That they need to be essentially revalved to match your application to get them setup properly.
How did you get yours setup?
TonyG
TonyG
#218
TonyG
TonyG
#219
I was told, by a very reputable source, than they typically are a more generically ordered shock. That the adjustments are very fine, thus the range is small (compared to say a JRZ that has a far wider range of adjustment). So if they aren't pretty close in their valving, you can't get them setup properly.
It's got me a little concerned honestly, about the time it will take to get them setup.
TonyG
#220
Did they valve them specifically for your car? If so, what was the valving they used? Mine are coming off a cup car so I'll have to have them valved.
TonyG
TonyG
We have the same rear suspension so that should be pretty similar but I have a custom double a-arm front suspension so those numbers is probably not really comparable.
#223
Tony, get them on a shock dyno before you instal them.
#225
Do you know the front and rear motion ratios for your new suspension setup?
