Help: can't remove valve springs with engine in car
At my last track day I noticed that on shifting I was leaving small clouds of blue smoke. I knew I had an issue, but after the track day it realy went from bad to worse.
So I decided to change the valve guide seals. But: the two conical "things" holding the springs/valves wont let go.
I have 7bar air pressure in the cylinder, but I just push the whole valve down.
I read somewhere that you can fill the cylinder with rope(!?) but I am not keen on putting anything inside the cylinder. I am not too keen on taking the head off either..
Any good ideas are welcome. So far I have only managed to change on two of the eight valves. These two worked realy easy, but the rest is stuck![Frown](https://rennlist.com/forums/images/smilies/frown.gif)
Any good tools out there?
![](http://i159.photobucket.com/albums/t134/kghaas/IMAG0301.jpg)
![](http://i159.photobucket.com/albums/t134/kghaas/IMAG0302.jpg)
Normally I will tap the tops of the valves where the keepers are before attempting removal to "unseat" them. Then after reassembly, tap them again to make sure they seated properly again.
Rennlist Small
Business Sponsor
Rennlist Small
Business Sponsor
Don’t bother.
If you are getting oil from the cylinder head its because of worn guides not bad seals.
951’s that run extended high rpms (over 6k) will wear their guides rapidly.
Replacing the seals won’t really help…..time to pull the head!
Thanks guys for good advise.
I will try the tap dance before I pull the head. I really can't up the pressure, since 7bar is all my compressor gives me.
I know if I pull the head, things have a tendency to get out of hands... And I will miss the rest of the season.
I made a pry bar that would allow me to compress each valve spring by pushing on the retainer without touching/risking damaging the valve stem. Some keepers were reluctant unsticking from their respective retainer but they eventually came off after several tries, though that was on a rebuilt head with only 18k miles.
102 PSI in the chamber holding the valves closed, 130 on the spring (and keepers)... slightly stuck keeper and the valve is opening when you compress the spring...
If it were me, I would use the rope... but then I have done it before...
Thanks guys for caring ![Smilie](https://rennlist.com/forums/images/smilies/smile.gif)
Did the tapping and all let go easily.
Only one seal was firm, and two looked like this:![](http://i159.photobucket.com/albums/t134/kghaas/IMAG0305.jpg)
Looks like i found the reason for the blue smoke....
Hopefully the head can stay on for another year.
New seals are glued and will hopefully stay in place
