86 Stock Turbo Exhaust Picture(Exhaust leak issue)
I am trying to see what kind of clamp/flange they used to secure it to the rest of the exhaust. I always smell exhaust and this is after I replaced my cat section of the exhaust with one from a 1987 car. I cut the flange piece on the 87 cat pipe off so that it would slip right onto my 86 car. I then used a 2" exhaust clamp to hold it together. Ever since putting this cat pipe on it has been leaking. I smell exhaust anytime the windows are down. I have replaced the hatch seal and that helped a little bit.
Could someone give me a good picture of the wastegate tie in on a 1986 951? This will help me figure out what I need to do next.
http://www.ebay.com/itm/Porsche-951-...r#ht_500wt_949
Is this what the 86 Turbo is supposed to have?
No the pics is for the bracket that holds the gate up.
I have my cat pipe, dump tube and gate. You can send me a pm with your email adress or tell me what arear specifically you want a pic of. My '86 looks identical to Zeff's from memory. I can go out to the shed and double check if needed.
Also bear in mind, I believe there where 2 or 3 designs for these pipes in'86. Is yours a two piece crossover or 1 piece? That will make a difference, I think. Mine is a two piece and looks almost identical to an '87 and up pipe with the exception of how the flange is on the crossover.
