transaxle oil
transaxle oil
I'm looking for advice on the most suited gearbox oil for an aor trans with guard 50/80LSD in my race car.I'm in Europe so info on type of oil is better than just a brand name since not all North-American brands are available here.
As I understand it the friction modifier is only for street cars that want to have a more quite and smoother operation of the LSD. But a race car should not use it.
BUT with oil there is so much different opinions...
You do want to run friction modifyer in clutch type LSD's. I need to go up and post some info in the racing forum, since I've become a sponsor, but we've been seeing temperature drops of 20 degrees in multiple applications when using Millers over what is probably the more common brand. The Millers uses nanotechnology, which reduces friction, and does not break down under pressure like most of the high pressure additives you see more frequently. As a result, more power is transferred to the driven gears than heat is put into the oil. These results were in the Racer's Edge 996, a Grand Am Continental team, and similar results in many cars in Europe. I run this in my car: http://performanceracingoils.com/crx...0-nt-p-43.html
Here are some articles that were written about the stuff in Racecar Engineerin and Racetech Magazine (i.e. neutral sources, not paid advertisements):
http://performanceracingoils.com/PDF...eakthrough.pdf
http://performanceracingoils.com/PDF..._the_Gears.pdf
flipo, there is a distributor in Belguim, as Millers is new to the US, but somewhat established there. Here is what Millers' website shows: http://www.millersoils.co.uk/distrib...nd+Distributor
There are two viscosities, 75W90 and 75W140. There are versions with limited slip additive for both viscosities. Transaxles will generally run the 75W90 (which is what I linked).
