High Flow, Low Cost, 8V Cylinder Head Project
#166
In my research into a truly big valve head with a big bore (109 mm) it indicated flow of around 350 cfm at high lifts. N.B I have only tested a 53.34 mm valve in a 103 mm bore and the best result is a touch over 300 cfm @ 0.500". That head had stock 928 valve position.
The big valve head will be a 55.88 mm in the 2.7 litre head and running radius hydraulic tappets with around 16 mm lift. When I extrapolate the results from previous testing adding in the movement of the valves away from the bore albeit the exhaust gets a touch closer to the bore therefor 350 cfm seems is quite reasonable.
Back to the 48 mm valve, here's our development;
https://rennlist.com/forums/928-foru...fold-test.html
