Alex's '92 968 - 951 Transplant Project
So yeah this probably should go in the 968 forum, but the car will be more 951 than 968 so I figured it could go here (plus that forum can be pretty dead at times
Drove 1700 miles round trip from Seattle to San Francisco this past weekend to pick up a '92 968 in Grand Prix white. Built a custom dolly to load the shell onto and we ran into a few snags so it took a while to get it loaded but it worked much to our surprise!
Car originally a tiptronic and was parted due to the hood flying up and hitting the windshield. Car is basically a bare shell with some interior and doors/glass. The plan is to swap the entire drivetrain/suspension from my '87 951 over to it. Still deciding what I want to do with the interior, I might just strip it and make the car more track oriented. I will obviously need fenders/hood/front bumper and depending on whether or not I can find OEM for a good price I might go fiberglass with those.
So, the parts I will be swapping over are:
-Stock 2.5L 8V engine
-Widefire head gasket
-Upgrade valve springs
-Bored TB
-Custom FMIC
-SFR 2.5" IC pipes
-Aluminum Griffin radiator
-Greddy Type S BOV
-Garrett T04E 60 trim/KKK #8 stage 3 turbo
-3" SS test pipe and catback
-JGS 40mm wastegate with SS adapter plates
-CEP semi-solid engine mounts
-Wolf 3D V4+ standalone EMS with J&S SafeGuard
-1000cc RC Injectors with 3bar FPR
-SS LR fuel lines
-SS brake lines
-Bosch 044 fuel pump
-S2 AOT LSD transmission
Probably a few other mods I'm forgetting. Also plan on doing some upgrades to the suspension and clutch while I'm at it.
Now for some pictures of the adventure!
Tow rig and Mt. Shasta in the background:
![](http://i14.photobucket.com/albums/a303/alxdgr8/7724694e.jpg)
Golden Gate Bridge:
![](http://i14.photobucket.com/albums/a303/alxdgr8/f3c5fbf2.jpg)
Driving up the steep hills in a manual truck was fun (thankfully no trailer):
![](http://i14.photobucket.com/albums/a303/alxdgr8/a5c96b19.jpg)
Loaded and ready for the long drive home:
![](http://i14.photobucket.com/albums/a303/alxdgr8/2012-05-20_08-20-13_104.jpg)
Wish we had stayed in northern CA for the eclipse, but I did manage to get a snapshot just south of Portland that turned out well:
![](http://i14.photobucket.com/albums/a303/alxdgr8/dedc8e5e.jpg)
The winding road in wine country that my GPS took us through at about 2AM. Not much fun in a truck and trailer:
![](http://i14.photobucket.com/albums/a303/alxdgr8/876eb7a7.jpg)
A lot of work to be done:
![](http://i14.photobucket.com/albums/a303/alxdgr8/2012-05-21_20-26-44_486.jpg)
Under the cover while I spend the next few months tearing apart the 951:
![](http://i14.photobucket.com/albums/a303/alxdgr8/2012-05-21_19-47-50_426.jpg)
What's going in:
![ooops](https://rennlist.com/forums/graemlins/icon501.gif)
-Bored TB
-Custom FMIC
-SFR 2.5" IC pipes
-Greddy Type S BOV
-SS LR fuel lines
-SS brake lines
Golden Gate Bridge:
What's going in:
![](https://i14.photobucket.com/albums/a303/alxdgr8/de1b40b1.jpg)
Rocket Scientist
But yeah, a lot of work but in the end I will have a clear title car with a better body and a much more unique and rare car.
Awesome project. I scratched my head more than a few times over that 968 shell. That shot of the bridge is about 5 miles from my house. You also drove past two PCA autocrosses that I know of this weekend.
Couple new parts, Tarrett Engineering sway bars and TurboS/M030 calipers. Not sure if I'll actually use the calipers on the car, but I'll be using the fronts for bracket/adapter designs and mockups for this and another project. Already have another spare set of rears too so they'll probably just get blasted and powdercoated to clean them up.
![](http://i14.photobucket.com/albums/a303/alxdgr8/2012-05-31_21-53-12_594.jpg)
![](http://i14.photobucket.com/albums/a303/alxdgr8/2012-05-31_21-57-20_9.jpg)
LUV it I wish
I had another white white car , I finished mine up now Im looking to due the blue one ... The biggest pain for me was the making the dual hood release. Next one I go with the set up you're using , Front mount cooler .
What intercooler are you useing was it a base core the you added the end tanks ? Dp951
![bowdown](https://rennlist.com/forums/graemlins/bowdown.gif)
When you use the 951 intercooler you have to use hood pins or make your own lock system because of the front latch area . ![banghead](https://rennlist.com/forums/graemlins/banghead.gif)
I 'd like to see pictures when you mount yours under the bumper cover.
