"Jiggle the connectors" solved...
#31
There isn't much to a connector. It's literally some tiny pins, some wire, and a plastic housing. Made in China or not, I doubt it's the connector's fault - frankly it's pretty hard to screw up. Besides you're not actually jiggling the connectors, are you? (On my car, I move the wires around... the connectors themselves are mounted to that bracket and don't move.)
My guess is that it has to do with electronic interference. Maybe the BMW sensors aren't shielded as well or something?
#32
I do actually jiggle the connectors.the room for error in connector design is to ensure they mate solidly and repeatably, particularly where the little spring clip is concerned.
Given that all of my connectors are in good nick and they are all mounted to the bracket with the appropriate clip, it seems that the connectors are not mounting solidly. I've even gooped em up with dielectric grease; didn't seem to do much.
#35
I have a new LR harness and new BMW sensors and still have to wiggle the joint every once in a while. Maybe every 15-20 starts. I used the extra length in the leads to mount them higher up an easy to reach. It almost never happens at the first start of the day, mostly after a short drive. Not a major headache but would require a training session if I ever loaned the car to someone.
#36
I think those of you (us?) who still have this problem after changing the harness and sensors, is to be more methodical in testing (I have not had a problem since changing the sensors, after the harness).
Pick ONE sensor and wiggle it. Did it start? How about the other? Starts now? Next time, do JUST the other sensor... Is it one vs the other...
If it is, swap the sensors. Did the problem follow the sensor ? Etc.
#37
#38
![nono](https://rennlist.com/forums/graemlins/nono.gif)
