valve spring tool -zero compression in #3
I am going to be removing the valve springs out of a 951. I would like to know if there is a recommended valve spring compressor tool out there. I am going to be pulling off the head as I have 0 compression in the third cylinder, no noise but it idles like a diesel...firing on only 3 cylinders. Thanks in advance.
