cone filter vs stock airbox
when i bought my 88 turbo around 10 or so years ago and it came with a k&n filter , which now it its all cloged up i used the cleaning kit a few times but its time for a new one, question is wich is better stock air box or cone filter i read that using a cone filter sucks in hot air,is that true or is there no bennift between the two they are the same?
i was waiting for some one to say that i used the search but says no one has dynoed to see if there is a difference, i read that the snorkel is very restrctive
Drive-by provocation guy
Bone stock car you will not see much difference.
Getting rid of the stock air box is more for a bigger turbo, MAF or more boost etc.
I have a Turbonetics TO4E Super 50 T3 #8 wet non BB, 3 Bar and 55 inj, I am using the stock airbox,paper air filter and AFM.I get 18lbs of boost at 3175 rpm I’m guessing between 300rwhp and 350rwhp. Runs Fantastic! Just have to Tweak the WOT map a little more.
So if you are below that then you are fine.
Brian 86 951
Brian 86 951
at 16psi i have 300wrhp, so if im under the 350 wheel i should just keep the cone filter on since i dont have a stock air box there is no point for me to spend the money on an airbox since i will not gain any performance
OK for some reason I thought you had a K&N in the stock airbox. So as Paulyy said you will run better with the cold air from the stock airbox.
If you did have a higher flowing filter, and the turbo is getting cold air, you'd have even better performance.
(Actually, there's no way you'd be at 350 rwhp, currently).
The bottom line is that the stock airbox configuration and/or sucking in hot air through a cone are both bad.(the hot air would be the worse of the two scenarios, if otherwise everything else is stock) Needs to be fixed and one will notice a definite seat-of-the-pants improvement. Best is a MAF, and be done with it.
