Engine Stopped - HELP
#48
I missed this first time around -- sorry about the motor.
Steve, I always found that getting the rear of the car up was the key to getting more clearance in front. The steeper the angle of the car, the higher the front has to come off the ground to create enough clearance...or am I missing your point?
#49
Hey Man
#50
I hadn't even thought about lifting the rear off the ground, but that makes sense as it will reduce the overall angle while giving maximum clearance up front.
Do you put the rear jack stands under the torsion bar tubes?
#51
Hey Man
Just remember when lowering engine to have enough chain to sit the engine on the ground or whatever you are going to sit it on. I have used cardboard when I needed the space to clear while on Jack stands. If you have enough room, a moving/piano Dolly works great. You can get those at harbor freight also. Drop the engine on Dolly then you don't have to wrestle with it to get it out from under the car.
You can also use the front tow hook and engine Crane to lift the front of the car to give you a little more room. Make sure not to try this with engine in car.
#53
I'm pretty sure that pulling the radiator is almost required... I'd recommend pulling the lower core support off too... It gives you a couple more inches when you're trying to get the bell housing past the torque tube.
#54
Thanks for all the advice guys, it sounds like I'll need all the clearance I can get. I was already planning to pull the fans & radiator, so hopefully I'll have plenty of room to wiggle it out.
What I'm not sure about is the wiring harness. It seems easy enough to disconnect everything from the engine and lower it out and away from the harness, but Clark's says to disconnect the harness at the DME/KLR and pull them through the firewall. Is there any benefit to pulling that out of the car, or can I just flop everything up and out-of-the-way while I drop the motor?
#55
Hey Man
#56
#57
Basic Sponsor
does anybody has a procedure like how to drop the engine under 3 hours?
#60
Basic Sponsor
