Door window not aligned properly
I have a problem with my passenger side electric window. The window comes a bit too far out, so there is no way to get the seal in between the window and the door. I can't either see any way to adjust the window, or am i missing something? On the rear of the windows it's fine, but front half is too close. Were talking about like 5mm too far out, as it's touching the clips on the door.
Location: Hawkinsville / Perry, Georgia, RETIRED USAF GO BLUE
1 Post
Hello, You will have to remove the door inside panel in order to adjust the window track. It would just be a WAG without looking at it.
http://www.clarks-garage.com/shop-manual/body-11.htm
Cheers,
Larry
Cheers,
Larry
Cheers,
Larry
Cheers,
Larry
