Timing crank pulley orientation
I am looking at the pulley stack and was wondering should the flat part(lipped end) of the timing pulley, from the crank, be facing the engine or the balance shaft pulley? Sorry for the odd phrasing/question. Thanks for the help in advance.
Ok. That is the way it is on the car. I have a lot of play on the power steering and alternator pulleys and the crank bolt is fully tightened. Could something else not be orientated correctly to allow for that much play?
Thanks for the help Van.
Ok. I am pretty sure that I have that in place and that still wouldnt account for the amount of play i have with those two pulleys up front(power steering and alt.). I will take a look at things and post what I find. Thanks again for all the help.
