What's the real deal on fitting the top strut nut with an impact?
I mean, if you're careful and it spins just a little is it really a problem? Who has done this plenty of times without issue? Does spinning the shaft really hurt the valves or can it just damage the seals if it spins A LOT?
Hey Man
I would always just set my impact at a low setting, cinch the nut down with the wheel unloaded, lower the car and torque it to spec or just use the impact if you are familiar with it's settings. The shaft doesn't really turn that much with an impact once there is weight on it anyway from what I remember.
A little off topic, but mine come loose after driving for a couple of weeks not sure what was done wrong, but it is weird had to add a secound nut for now. Any Ideas?
Or maybe just use an impact
