Rear axel bolts keep breaking?
By their nature, bolts in a situation like this all like to be the same torque - that's why it's important to use a torque wrench. If they are *different torques*, vibration harmonics will set up, and bolts will start vibrating loose. You use a torque wrench on your wheels, right?
Lug nuts should be torqued to 96 foot lbs. Over-tightening can lead to warped rotors (this was a big problem on Supras); and, of course, under-tightening can lead to them loosening.
You have a performance automobile there, not a farm tractor.
ft lb?
I'd use a torque wrench on a farm tractor too.
Pick up a Haynes manual at the local auto parts store. Most of them have had the 944 volume, when I looked. You can also search for a link to download the factory work shop manual, but the Haynes manual will get you 98% of what you need.
In all fairness I have been considering replacing with better hardware and I like the lock washers.
I need to inspect how that has held up and go from there.
Good luck.
With stock bolts use Q tips soaked in brake cleaner to get out all the grease, then locktite blue the threads and torque to 30 ft lbs.
Or use these:
http://garage.ideola.com/prod-Stage8-GB.html
Or use these:
Rennlist Junkie Forever
I have an 86' 951 no major add ons just a spec stage 1 clutch and stage 2 chip set and my rear axel bolts keep finding their way out and end up getting sheared off. I'm not stupid I used plenty of the heavy duty lock tight on the treads but they still keep finding their way out. I don't know if I'm doing something wrong or if I have a greater problem causing them to find their way out but if any one has this problem or knows what to do about it I would love to know what I can do to fix this.
You have to make sure the holes are clean of grease when you stick the bolts through.
Use brake cleaner to clean the holes as well as the stub axle holes.
Push the bolt in and pull it out and make sure no grease is on the bolt.
Off of memory, I think I torque them to 38ft/lbs.
Then red locktight it and torque to spec.
Then I take a Sharpie marker and make a line on SIDE of the bolt head so I can quickly look to see if the bolts have loosened without having to stick a wrench on it.
But if it's clean, red lock tighted, and torqued to spec, they won't come loose.
TonyG
Location: Hawkinsville / Perry, Georgia, RETIRED USAF GO BLUE
1 Post
I am surprised that you have not used Clark's garage.com for your DIY maintenance. Check out the link below and read through it. Near the end will give you the proper torque value.
http://www.clarks-garage.com/shop-manual/susp-01.htm
Cheers,
Larry
Cheers,
Larry
I tighten mine in 3 steps. First I go to 10 ft. lbs. on all the bolts, then 20, then 30. Each round, do them in a star sequence -- not in order. If the axle were the face of the clock, tighten the 10 o'clock bolt first, then 2 o'clock, then 6, then 12, 4, 8. I've never had them back out when using this approach (knock on wood).
Why 31 posts into this thread before these most important steps are revealed?
I don’t clean grease from threads or use locktite and have never had these bolts back out on any front or rear wheel drive car. Mostly feel lucky if I don’t strip the heads out when removing them, they are all still tight from being torqued correctly.
At a minimum two torque wrenches are required to cover most torque ranges on cars.
For the rear axel assembly on this car the range is from 7ftlb (brake shield bolt) to 368ftlb (bearing hub nut). I have three wrenches and my strongest one only makes 250ftlb, so I’ll stop by the Freightliner garage for the final torque on the rear axel hub nut when I change those bearings.
Turning bolts on these cars without using a torque wrench is like putting air in your tires without using a pressure gauge, eventually something is going to fail.
I’m sure some seasoned mechanics would say they have calibrated wrenching strength, but most of us do not. Why guess at a task that is so important?
