Brake Upgrade....86T Only
I would personally be very interested in a bolt on lexus ls430/boxster s rotor option for 86 turbos. I know lots of other guys would too, there are a lot of 86 951's out there.
The LS430 caliper can NOT be used because the turbo spindle ear spacing (94mm) would not allow an adpter for the LS430 caliper radial bolts.
A solution for 86T would be to swap in the early strut/spindle/hubs......The Hubs are much stronger than 86T hubs.
To keep the 86T hubs/spindles/struts you could build a larger rotor/hat and mount Wilwood SL4R's or Sl6R's and adapter would work since the radial spacing on those are 5.98"
LOL, I just realized I sold these months ago. After 15 or so different brake combos, I stopped counting.
BTW the hats/rotors I'm working on are 309mm x 32 and 13lbs total. The M030 rotors are smaller dia at 304mm but weigh 19lbs.
