Stable wiper blades
Might seem like a silly question but my blades are jumpy on any high speed secton. I used to have a little aero deflector on the traditional Bosch style wiper blade that seemed to keep things put but that disappeared.
Anyone have any experience with the single piece blades like the Bosch Aero wiper, are they any better at speed?
Bosch "beam" or flat blades are wonderful. I have them on my GMC truck and A6; I think probably the Icon but I don't remember for sure. I don't know if these fit our cars. My 951 has conventional metal wiper blades and by comparison they are worthless.
Also, try claying or polishing your windshield. I have not done this, but it makes sense that you would get a buildup of rubber after a while.
I didn't care for the beam blades on the 944, even with brand new 968 dual-spring arms. The main problem was with the passenger side - they don't flex enough to wrap around the windshield so they miss a huge area at the bottom of the sweep and the end sticks up when they're in the parked position. I've tried Bosch, Valeo and NeoForm (Trico) and they all had the same problem. Valeo was the least problematic (but it still missed the bottom outer edge of the passenger side). NeoForm was the worst, it would bow too much in the middle and miss a section on the driver's side too.
I've gone back to standard Bosch blades. It still misses the lower outer edge on the passenger side, but it's only 1.5" instead of 3" with the beams. I'm reluctant to try other blades since the majority of them are now made in China and the last Chinese blades I put on my Jeep lasted only a couple of months before falling apart.
I never bothered to look, but are the 968 arms the exact same length as the 944? If they're a little longer, maybe that's why mine miss the outer lower edge of the passenger side. It annoys me enough that I'm considering using a shorter blade on the passenger side.
