FS - 1987-88 944 Turbo / S2 & 88-89 TurboS Brembo Big Brake Kits
944 Turbo S Big Black Brake Conversion Kit - 88 (S) - 89 Turbo S Cars Only
Brand new Brembo branded Brake Kit includes -
(2) Front Cross Drilled Rotors
(2) Sets of Brembo Brake Pads
(2) Big Red 993T Calipers
(2) Stainless steel brake lines
(2) Required Bolts
$800 + Actual Shipping.
To install on a 87-88 Non-S Car, just get the adapters from Lindsey or any other vendor and you will be good to go!
(2) Required Bolts
^^ Kee-rect!
Just checked the specs, these rotors will not work with an mo30 car, the hat offsets are wrong. You must use 964 3.6 turbo rotors on mo30 cars.
-Nick
Hi Nick,
i believe in order to use the 993 drilled rotors you must remove the hats and replace them with the lindsey hats
http://www.lindseyracing.com/LR/Pors...789-BBHAT.html
