Need Help picking an MAF kit !!
Drive-by provocation guy
Rogue.
But you should contact each vendor first and ask them your questions and your set up and then come in here and ask for further clarifications.
Talk to both vendors. Beware of hard sales pitches and the "It's the last one left, get it while it's hot!" line.
I've had both and am a current Rogue customer. Take that for what it's worth.
You will need new chips for a maf no mather what maf you choose . I prefer Vitesse but i know people have had good experiences from both LR and Rouge even autority with close to stock car . If you plan going further after a while you may want bigger injectors while going for a new maf, so that you do not have to get new chips 2 times.
I have a similar set up (see signature). I have been running the mafterburner since I bought the car 4 years ago. It's easy to tune, can run off my laptop while driving, A/F is right where is should be at WOT. I have been running around 19psi on stock 26/6 with no headgasket problems. Although I rarely run to redline, I generally shift around the 4-4500 mark when I am pushing it.
