need help with tyre choices
Professional Hoon
done some research and found out the stock front tires where 205/55 r16 and rear: 225/50 r16. so the back was a size smaller and now we've gone down 1 size for the front and back as "standard"
I'm leaning towards the Toyo T1R but i've read they've stopped making them.
Nexen n3000 could be another option, but i keep seeing "good for what they are" probably means good cheap tyre.
Or i need new rims
Or i need new rims
![surrender](https://rennlist.com/forums/graemlins/surrender.gif)
I've got Continentals on the rear of mine for the road from Stuckeys.
Don't try and run R spec tires on our goat track roads in Melbourne, I get punctures if I leave my race wheels on.
As a slight diversion, do you attract any attention from the police? My car is far from stock in appearance but I've not been pulled over(yet!)
Professional Hoon
i just ordered toyo T1R tires $320 fitted. seems okay.
i looked at continentals, but the feedback wasn't that good.
you're lucky! Which side of melb you from though? Outside my car looks 90% stock, except the twin exhaust and my front mount. i used to get pulled over at least once a week, not to much any more but i always get looks from the police officers. It's more because i'm a P Plater.
BTW you've got a PM
BTW you've got a PM
You can quite happily run a 245/45 on a 16x8 - I have done it before. The tyre will work better stretched out a bit on a 16x9 though.
Professional Hoon
the plan is when these tires are finishes, i'll buy new rims with fatter tires! 235 or 245 fronts and 275 rears
i "tested" the toyos lastnight and they've got some serious grip.
