Stall from fast rpm drop
I ran that exact same setup without any idle issues. The only thing I had to do was adjust the AFR with the MAFblaster in some cells. If it was a transfer function in the MAX DME chip, we all would have had idle issues.
I checked TPS, idle set screw, vacuum leaks - all ok.
I sprayed some cleaner into the ISV.
I adjusted the curve in Mafterburner - basically leaned it out a little in the area just off idle. My theory being the car was getting too much fuel as the MAF drifted back to idle.
It is better - the car won't stall, but it comes close. If I am accelerating and then have to get off the gas and depress the clutch, the RPM will fall to "Zero" and then bounce a few times before settling down to idle.
MZMAN - you have a PM.
Please continue to update on this thread - I have the EXACT same problem. I have a LR MAF, 951 Max chips. If I am on the gas above 3000 rpm or so and depress the clutch, the engine will stall ~50% of the time. Sometimes it will "bounce" and catch itself just before stalling.
If I coast to a stop sign while still in gear, then depress the clutch, no issues. Idle is fine, right at 900.
AFR's are perfect in every situation.
Warm vacuum is at 20 inhg.
I will double check my TPS and clean the ISV.
I did change turbo's over the winter so I will also double check for vacuum leaks- or maybe I set the throttle cable too tight and I am cracking open the TPS even when off the gas ???
Any help is appreciated.
MAF conversions have been misunderstood by 99% of the public for a long time. That allowed some real crap like Pro-M to get out on the market (ever seen the ones with the potentiometers!?). When I say real crap, I mean that when a front came through and the barometric pressure changed, the tune went to crap. Most 2.3Turbo Ford guys I knew that had them ended up taking them off. The 944's are more tolerant than a lot of others. And like I said, Lindsey has a very good reputation, so I am not knocking them, but the issue is really a software/coding issue, and that takes a very different skillset than even the best engine builders and tuners have. I had a friend who wrote strategy for Ford who had a 2.3 Turbo, and he and I did a lot to make a good system for that engine (and he did most of the heavy lifting). It involved a whole lot more than just changing a transfer function, which is what most aftermarket systems do.
But again, like I said, you can probably get around the issue by cleaning up the ISV and increasing the idle speed. The Vitesse and Rogue systems are the best optoins out there, but obviously, there is a big investment with that. If I were in your shoes, I would probably be inclined to try to make what you have work. There is no way I could do what those two guys did.
I have a modified 1-series M now for my go fast kicks so don't feel like spending a ton on a Vitesse setup like I wanted when this problem came up a year or so ago.
It is so refreshing to come back to rennlist after being over in bimmer world for a little while. BF.C, e90post, 1addicts, etc. the quality of users and expertise here is far above anything you can get over there.
hows the condition of your blow-off valve?check if the diaphram is damaged.aare your venting to atmosphere?that could cause the same issue,because I am experiencing this issue after each full WOT, then letting off the gas, my tach needle would goto 0 and sometimes go back to normal idle but usuall dies.Ill also be checking my ISV and vac. leaks, though im pulling 16+ -mmHg at idle.
I’ve struggled with this several times. You definitely need to confirm all the basics are good – TPS, ISV, Base Idle, vacuum leaks, grounds, temp sensors, etc. What usually happens is that the MAF signal voltage is remaining too high when the rpms get to idle speed, and the motor is flooding as a result. Normally, at idle, the MAF signal voltage (as measured on pin 7 of the DME) is around half a volt, plus or minus. When you floor it and let off, the voltage needs to go from whatever it was (say 2 volts) down to half a volt or so before the rpms drop to idle and the injectors kick back on. Normally, this isn’t a problem as most MAFs react quickly. However, if you have a vacuum leak, it will act much like a blow off valve vented to the atmosphere – i.e., it will throw off the air fuel ratio because the MAF is measuring more air than ever makes it to the cylinders and as a result the DME will deliver too much fuel. Also, if the MAF is too close to the bypass valve (or turbo) or you clock the MAF in the wrong way, the bypass air (or turbo) can create a windstorm in the MAF and generate a mistakenly high voltage. Early MAFs were notorious for this. Speedforce racing made an early name for itself by figuring out to move the MAF further away from the bypass valve. You can test all this by watching the voltage on pin 7 of the DME via datalogging or a friend with a multimeter in the passenger seat. If you floor it and let off at low RPMs, you will probably see the voltage remaining too high (e.g. twice your steady-state idle voltage) when the RPMs come down to idle speed. If your fuel controller has the granularity, you can mask the issue by strategically taking lots of fuel out under and around where it idles (but preserving the normal idle itself). As for a real cure, every time this has happened to me, it’s either been a vacuum leak (even though I would have sworn on a stack of bibles I had none) and/or a base idle set too low.
So here’s what I’d suggest. First triple check all the basics. Then check again for vacuum leaks – pull the I/c couples off and bend them in your hands looking for slits that might open under pressure, etc. If that’s fine, then I’d set the base idle (the screw on top of the throttle body) as high as you can while still allowing the system to return it to 840+/- when warm. If you still have the issue, try clocking the MAF differently and/or extending it as far away from the bypass valve and turbo as possible. If none of that works, chuck it and buy a Vitesse MAF.
Pulling up this thread to see how many others have this issue? Having seen it too many times, I now have a foolproof hardware solution, but curious if it's even relevant still in our modern MAF world...?
I have this exact same idle issue. Although I have a Vitesse MAF, this started occurring about two years after the conversion. It popped up the last two months that I was in the U.S. and didn't have time to work on it, so I just 'drove around it' like a previous poster described, driving down through the gears until I came to a stop so that the idle did not drop quickly and kill it. I won't be able to troubleshoot this until December. I have a WB, but I don't recall exactly what it was reading when it died, I was too busy trying to 'catch' it with the accelerator.
I followed all of the suggestions in here and upping the idle was the only thing that helped a little. I'd be interested in a hardware solution, but also thinking about going to a M-Tune maf setup and ditching all of this.
Would be interested in seeing what your hardware was.
Basic Sponsor
i have the same issue with the 2nd gen lartmobile
If there's not an underlying issue like vacuum leak etc, this can be fixed easily by changing a parameter in the software. When the tps goes to idle and the rpm is above a certain rpm the dme turns the injectors off, lets the rpm drop, then it turns them on at a certain rpm to "catch" the engine before it dies. The "turn on" rpm is easily set on the chip. People also have this problem with lightweight flywheels. Whoever made your chips should be able to easily fix this for you (if there isn't some other problem).
Thanks, and yes, it can easily provide global fuel adjustments, but because it's all software based, it can also adjust fuel based on any input desired -- rpm, engine temp, manifold pressure, time of since start up, extra tip-in, time of day, you name it... I'm going to get started on timing adjustments for a more complete piggyback -- stay tuned.
I'm staying tuned to this. I'm on a bit of a personal mission to see how far I can push the AFM. Mine is ported to hell and back and I'm interested in using something like this to add fuel based on a MAP reading to compensate for the MAP levels which exceed the AFM's ability to control fueling. I spoke with Joshua a while ago and he told he could accomplish the same thing on chip, but that it would of course be an iterative process to get the variables correct. Something like this would make it easy to keep twisting a dial ( simplifying it I know ) to get my fueling correct. I think a true 400 rwhp is doable with an AFM-MAP tune.
