Water/Meth Inj - Snow Perf on HP TV
Old 02-23-2012, 12:46 PM
dnovak
dnovak's Avatar
Snow Performance makes a stage three system for cars that uses a digital controller that measures EGT and Boost pressures. It is not an on off switch it is a VFD for the pump (Variable Frequency Drive) so the pump can operate at low speed while everything is low temps and pressure and ramp up with a 1:1 ratio. This was the system I had on my Duramax and I have already talked to the guys at Snow a while back and they can make this happen. I would suggest mixing your own Methanol and Distilled water, much cheaper to buy in bulk and mix as you go.
http://www.snowperformance.net/index.php
Old 02-23-2012, 12:47 PM
dnovak
dnovak's Avatar
ah, maybe i was a little late on my post, you guys are all over it
Old 02-23-2012, 12:49 PM
dnovak
dnovak's Avatar
what about using this on an E85 car on crazy high boost? Hmmmm, would the E85 act weird with the added water
Old 02-23-2012, 01:39 PM
pole position
pole position's Avatar
You can run 100% meth with E85, as a matter of fact I would not mix meth with water, I use meth only with pump gas.
Snow, AEM,Devils Own etc are all subpar IMO in comparison to the Aquamist HFs4 due to the very sophisicated failsafe
Old 02-23-2012, 02:03 PM
blown 944
blown 944's Avatar
Yes meth injection can be run with e85. I've done it on my supercharged car.
It's not really rocket science as you can run very rich with methanol without any real power loss. The failsafes would be nice though. Really an egt and level sensor are all that would be mandatory IMO. As long as it could lower boost there should be no problem.
Old 02-23-2012, 02:11 PM
pole position
It's not only boost you need also a timing retard
Quick Reply: Water/Meth Inj - Snow Perf on HP TV
