tuning a maf piggyback - power perfect
I've been working on the car in my avatar for ~3month now. and I think I'm down to just getting the tune, and I'd like some advice that I could not find by searching.
as an fyi, I've read tons of threads with great information about diy tuning, I've read all the tech pages at lr..etc
I'm tuning a 2.5l turbo with:
k27/8 turbo
LR maf (stage? dont know)
3" straight pipes (although I need to put a muffler on)
I dont know which injectors I have, they are black, not green (I will find out).
The tools I have to tune with are:
- a working wideband 02
- an adjustable fuel pressure regulator
- a power perfect maf tuner that have successfully connected to with my laptop.
I believe there are no after market chips in the dme.
so what I am trying to do is to program the output of the maf to match the transfer function the dme expects using the piggyback.
first, is there any way to test/record what the transfer function of the maf is? just to prove it was in good working order I wired up my volt meter to the output of the maf and blew into it. I could get it to only read 1-2v. would that be normal? I guess I dont know how much air actually flows over this at full boost.
here is what I was going to do:
- current fpr is set at 40
- when warm, idle is rich
- rev to 2k is lean >14.7
- rev to 3k is lean low 14.
at idle, I cannot give less gas via the tuner, only the fpr right? so I was going to back that down a bit to get my idle where I want it.
then start using the ***** to increase the amount of gas at each rpm hitting my desired af value. after a few iterations of this, I should have a pretty decent map.
my concern really is that the input voltage will only go so high, that it limits me to a small range of used cells in the mapping, and only 1 or 2 pots to use.
thanks as always
k27/8 turbo
thanks as always
Basic Sponsor
k27/8 turbo
thanks as always
k27/8 turbo
thanks as always
k27/8 turbo
thanks as always
k27/8 turbo
thanks as always
How does that 27#8 drive?? is it laggy??
Good Luck with the tuning
I havent really driven it yet, for fear of detonation without a proper tune. I'd say its pretty laggy, the boost (the one time I tried it) kicks on at ~4k. Seems a little high even for that turbo. WHen it kicks, it kicks like a mule tho!
what maf do you have? and out of curiosity, how many lights are lit up when you first feel the boost kick?
Do yourself a favor and get rid of the power perfect and going with something different. I had this setup for a few years and could never get it to hold a tune. Lart is correct with the way you tune it, very slow and very tiresome.
Or you could enter the new century...www.roguetuning.com
really, just bite the bullet and go for the M-tune. Install it and forget it. You will live in the world of perfect a/f ratios and not have to worry about setup of old world tech.
