Absolute best head stud??
It could possibly be that even though you are going to a larger stud which may allow more clamping force to be applied, the problem would then be transferred to the alloy block. The thread in the block ( being alloy) may only permit a certain percentage of extra clamping force before it pulls the threads. Certainly something to think about.
On that subject I do remember Adam talking about drilling the entire block so that it's one length of bolt holding the head and crankshaft girdle. I'm not convinced that this would be a good idea either as drilling the block may cause weaknesses.
Sean
Sean
Forgot about the new head.... Even at lower boost, you're probably getting quite a bit more air in the cylinder.
Race ware and cosmetic gaskets. No problems so far. With the ARP studs and their lubricant you get very consistent torque numbers which means even loading on the gasket. Which in my opinion is a good thing.
Rocket Scientist
I think it has more to do with the head design and the actual head deforming rather than lack of head stud strength. Meaning it will take more head studs than stronger head studs. It's probably a combination of the large bore size of the 944 (essentially the spacing of the head studs) and the weakness of head.
You have to compare what's going on in the Porsche world with what's going on with DSM's. They're simply pushing much harder than we are here and we can learn from a lot of what they experience. Yeah, a different engine but the physics haven't changed.
While chasing my problem, I had Heritage make me up a new block with the big Millege/Heritage studs. They are mighty impressive and the torque spec is unreal -- I have no doubt, all things equal, they will hold more pressure at the limit. But I do not view them as essential for anything but the most extreme (or extremely used) motor.
Have you tried "new" stock head studs i have had no head lifts or head-gasket problems on my car. I wil never go for anything other than stock and a cup gasket "widefire".
Tom, thank you greatly for sharing. I certainly appreciate it.
The compression is definately a limiter. It feels great around town, but for making high hp I am not sold on it. I have never had these issues with the stock compression pistons. I was experimenting and obviously my past experience doesn't apply here (high comp blown alcohol)
We have pulled the timing down to less than 20 degrees at peak tq, which is far less than we ever did before.
So at this point, using your experience (that I trust) I may just call it a wash. I think I'm going to just follow through with the o-rings,new studs, and composite and limit my boost level. It is making good power based on maf readings and my mph via gps even at 19 psi. It seems to hold pressure fine at that boost.
Time to get the stroker done ......
That is what I'm going to do first. Along with o-rings. I see where you're coming from bc I have felt the same. However, the compression is a game changer.
I'll let everyone know how it works out
So you've had no headgasket issues whatsoever while running 26psi?? How many miles have you done like this and what sort of miles? Fast road or track miles with sustained boost pressures?
As for high compression turbo motors, the new modern cars have systems to handle it (my DD 335is has 10.2:1), but back when our cars were designed, there was a reason Porsche started off with 6.5:1 on their first street turbo car...
I have the PD large diameter head studs in my engine @ 175 Nm.
A side note, Milledge warned me about the Heritage studs not having the correct stretch design. But maybe they've updated their design.
When was that? I called Jon on the phone about a year ago and he said the only place to get his studs now is Heritage. He recommended I call heritage for them. They both said they developed the studs together...
