Timing belt rubbing on camshaft cover..need help!
Old 02-15-2012, 01:30 AM
ehall
ehall's Avatar
See that guy above, Van? Search for his video's on changing the t-belts and water pumps. Watch all three carefully and compare what you have to what he does. Those are the most informative vids on t-belt and WP changes that exist.
I used them and everything came out perfectly. Do the same. I bet you can narrow down your problem by comparing the the vids.
Great vids Van!
Old 02-15-2012, 01:54 AM
kev951
kev951's Avatar
did this all start after your water pump install? including the whine noise?
Old 02-15-2012, 10:48 AM
reno808
reno808's Avatar
Originally Posted by MK_951
Greenpoint..it's close to queens. Not to far to even go upstate. It's about a hour drive
if i am free this weekend i think i can swing by and give u a hand.
Old 02-15-2012, 12:26 PM
MK_951
MK_951's Avatar
@ehall thanks I'll definitely watch them @kev951 the whine existed before the water pump but the belt grinding was after @reno808 I'll probably be working on it a little during this week but I'll let you know how it's going if I need help this weekend.
Old 02-17-2012, 02:10 PM
MK_951
MK_951's Avatar
K..so I finally came around to doing the belt and came to find out that the cam sprocket gear on the crankshaft assembly was put on backwards. So I fixed that and the whine I was talking about was just my balance shaft belt being to tight. It still has a whine to it but not like before where it sounded like flying a jet plane. Thank you everyone for all the great advice, I really appreciate it.
Quick Reply: Timing belt rubbing on camshaft cover..need help!
