Can't track down this coolant leak
Problem with older systems...once one spot springs a leak...and it is fixed the pressure goes back to normal and the next week link springs a leak...Hope you get it sorted out soon..and that it is something simple
Took it into the shop. The took the covers off and we looked around. I didn't see it leaking really at all. They didn't see anything blatant that stuck out. There might be a possibility its leaking from where the oil filter is. Also my car is leaking more oil than normal they seemed to think that was the oil pressure sensor.
So I may be looking to sell it.
Still sounds like the heat exchanger, it seems you haven't ruled that out. I was leaning towards the water pump bearings when you mentioned that the leak can only occur while the car is run, but then again, the heat exchanger sees a very different environment (with hot circulating oil) when the car is run versus when it's not and you're just pressure-testing it, so I wouldn't rule it out just because it doesn't show up on a pressure test. What does the inside of the coolant expansion tank cap look like?
It's apparently a bear to change. I would need to replace my power steering lines as well because one of then has a cut in it. Probably causes a slow drip.
oil cooler housing/heat exchanger/oil filter housing/ potatoes patato's.
Sad reality was with the head off, you were 4 bolts away from having it off and the gasket replaced.
Basic Sponsor
Troll much?
It's always hard to know exactly what to replace when doing jobs like this. Stuff snowballs out of control quickly.
Basic Sponsor
My next question is would this cause more oil to leak than normal?
No oil leaks are normal, so anything more than that is not. An oil cooler housing (doesn't really house the oil cooler on the turbo, but you get the idea) can make a heck of a mess leaking externally though. I've never seen once leave puddles on the floor, but it wills sure drip down the side of the block and run over everything.
