Does anyone have the 'boost enhancer' from GPR?
Old 10-23-2001, 02:20 PM
Evilclown
7th Gear
Evilclown's Avatar
Post Does anyone have the 'boost enhancer' from GPR?
It looks like a good product, I was wondering if it actually performed as well as they claim.
Old 10-23-2001, 02:54 PM
Skip
Skip's Avatar
Post
That's the Linsdey Boost Enhancer, the same as sold at many aftermarket shops. It is exactly as described... "best-bang-for-the-buck". Spools the Turbo much lower in RPM's for early boost, and allows for manually adjustable boost (vice the standard OE preset)
Good Luck!
Old 10-23-2001, 09:45 PM
Doc
Doc's Avatar
Post
Evilclown,
For what it's worth, I have a used Lindsey Boost Enhancer I was going to put on e-bay. If you (or anyone else for that matter) is interested, make me an offer.
I only took it off because I installed the Lindsey waste-gate which doesn't work with the BE.
There are no wear parts so it's as good as new... just cheaper.
Old 10-25-2001, 10:06 PM
grodz
Cruisin'
grodz's Avatar
Post
You can purchase a pressure relief valve from grainger.com for $6.95 and epoxy a couple of 1/4 inch adapters at each end, then splice the hose coming out of the intercooler tube and just place the unit in betwen the cut, try to set the pressure relief valve at around 10psi and voila!
Old 10-28-2001, 11:10 PM
Evilclown
7th Gear
Evilclown's Avatar
Post
Well, I would make you an offer, but it'd be a bit of a waste for right now, since I haven't even bought a 951 yet, still haven't found the right one. I'm just checking around right now, getting an idea of what's around for when I do get it.
Quick Reply: Does anyone have the 'boost enhancer' from GPR?
