oil change
oil change
How often do you guys do an oil change ?
is it every 3000 miles ?
i add a quart every 400 - 500 miles - does this make a difference ?
thanks
1987 951 <img src="graemlins/drink.gif" border="0" alt="[cherrsagai]" />
thanks
One quart added every 400-500 miles is too much. You could be loosing it either from a worn turbo and/or worn valvetrain. Is the car leaving oil spots on the floor? What viscosity motor oil are you using? Try to isolate the cause of the consumption.
to bii
i edited my question. take a look!
about the consumption of oil - no no leaks.
its either my turbo or valvetrain. how can you differentiate. when i purchased my car i had it inspected. compression and leak down.
cyl 1 - 152/7% cyl 2 - 152/7%
cyl 3 - 155/5% cyl 4 - 152/7%
I was under the impression that the 951 compression range was from 10 - 6.5 bar absolute
(147 - 95.55). I won't tell you where these figures come from, so that I look really smart, but I think it is safe to say that it is a reliable source.
